| This is a general site search and does not include list archives. | |||||||
#11
Look here. http://www.jsmanufacturing.com/ Here is a direct link http://gallery.jsmanufacturing.com/m...g2_itemId=1432 And keep us posted on your result's i am curious how your setup works out for you. and take some
Josh 1989 Ford Mustang Turbo 1991 Ford Ranger Turbo 1999 Dodge Cummin Turbo Diesel
#12
As far as the pipes, and the intercooler, this is almost exactly how I have it planned. I think in these photos shown in the link, they modified a hotair intake to make it a open plenum set up. I am using a 87 intake because I like the the way the runners inside are designed. Also, I don't have all the welding and fabrication resources to modify a hotair intake like they did. I am re-using the stock hotair metal bracket which mounts the turbo on the passenger side of the intake. I also modified the upper plenum in the same way they did.
#13
I'm trying to add more pictures. I'm no computer geek.
#14
One more time
#15
This is how the current set up is configured. Keep in mind I haven't put the 87 intake/throttle body on yet.
#16
Ok, last picture. I don't know why I couldn't put hem all on at one time, sorry.
#17
Looks pretty trick.
You can only do one pic at a time here.
#18
photos look good and interesting setup. you can start a online photo album for free from a place like this http://photobucket.com and makes posting pics easier.
#19
I have decided to run the oil return line from the under side of the turbo, to the oil pan. I had a local welding shop weld a# 10 fitting to the flange for the oil return hose, after I cut the ribbed alloy hose off of it. I had them weld the same type of fitting to the side of the oil pan. Tomorrow, I'm going to Aeroquip and getting a 3ft long piece of hose to connect the two fittings. I want to replace the rear main seal when I have the oil pan off, its leaking like a mother***** right now. I'm waiting for a 87 TPS sensor to come in the mail from Poston. A good friend of mine is giving me a billet turbo inlet bell to attach to my TA-33 turbo. I believe after that, I will have all the pieces. I'm going on vacation for two weeks, but sometime around the third week in Oct. I should have time to complete the project. Stay tuned
#20
here's some more pictures
| Bookmarks |
