| This is a general site search and does not include list archives. | |||||||
what is the best way to clean my intercooler? i have it out of my car now.
thanks paul
87 GN /Boost @ 15PSI / 30# lucas inj / walbro /hotwired / AFP reg /cold air intake / RJC boost valve / RJC power plate / TT street chip. |
Carb cleaner, water, gasoline, parts cleaner. Pour or spray anyone of them in, swish around and dump it out. Repeat.
2008 rebuild, Comp roller cam, Cat stroker, RJC gridle, CPT66BB, PTE Stock Location, Champion iron, 60# Mototron, ported throttlebody, RJC Power Plate, Jimmy-built trans w/Precision Vigilante converter, ATR SS dual exhaust, Razor alky. |
Water is probably least effective.
I used 2 cans of carb cleaner...... spray in, shake it, repeat till pours out clean.....took about a can and a half before it poured clean, I taped a shop vac to one side and a rag to the other and let it run for about an hour...dried nice
I used Xylene, toluene and some other enes that evaporate fast....
IL KIM 85 GN w/86 motor, TRW pistons, Weber 206 billet roller cam, EGR welded, o/sized valves, 130psi springs, roller rockers, 3000 conv, adj w/gate, FPR, custom rad, KB ram air, ported, KB headers, Walbro 340M/hotwire, 60lb Hi Z, CPT66bb |
anyone try bringing it to a radiator shop?
I think that is unnecessary. The stuff inside is usually not quite as baked in as radiator gunk.
| Bookmarks |
