Rear Main Seal
Guys ive change the seal twice ,filled side groves withULTRA BLACK HI-TEMP RTV SILICONE.Anyone have any ideas on what im doing wrong??????????
Re: Rear Main Seal
Haven't had the pleasure of doing my rear main yet, but make sure your valve covers and the rear of your intake manifold aren't leaking. Oil leaking from valve covers can run down the back of the motor and look like it's your rear main.
Re: Rear Main Seal
Is the shaft OK? When you installed the seal, you offset the split per standard procedure right? You're not leaking at the pan gasket?
How much of a leak are we talking about? Is the PCV valve good? Do you have breathers on your valve covers or at least the driver's side? I agree, the leak may be coming from the intake manifold gasket or from the back of the valve covers. Patrick |
Re: Rear Main Seal
The intake manifold and the valve covers have all new gaskets,i have two breathers on the valve covers,the oil pan gasket is new,i can see it dripping at the corner of the rear main cap where it meets the oil pan. it leaves a good puddle on the floor,besides the flex plate slining the oil all over the underside.
Re: Rear Main Seal
go to the ford dealer and get some diesel silicone, it will seal better then anything
Re: Rear Main Seal
i rec' checking for severe blow by and also every pcv must breath on the other end . my crank moved so bad and groved up to the point i tore her down.
got any bad vibs in motor/flexplate ??? it would be fantastic to install a over size sleeve on the crank like jasper eng uses on their 1-piece crank seals for ford junk hth |
Re: Rear Main Seal
