Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Technical Topics > Cooling Systems
Old 03-21-2012, 06:31 PM
smallblock413's Avatar
smallblock413 smallblock413 is offline
smallblock413 is on a distinguished road
Default Cool???
installed 160 T STAT today but fan still not kicking on until 210 then cools down to 196 fan shuts off then 205-207 its back on could the fan switch be bad...
smallblock413
aka;'87 BLACK BEAUTY
"TRESSPASSERS WILL BE SHOT"
SURVIVORS WILL BE "SHOT AGAIN"..
Old 03-21-2012, 07:14 PM
Lightbulb Re: Cool???
Do you have a chip set to turn the fan on at a lower than stock temperature?
Are all of your fan relays working? Does it only come on "high", or low at first?
Old 03-21-2012, 09:17 PM
Default Re: Cool???
chip is stock im sure...chip numbers in chip section...where are fan relays ?? driverside fender?
high so i guess a relay is bad...
smallblock413
Old 03-21-2012, 09:37 PM
Thumbs down Re: Cool???
No. The fan is turning on when the stock chip is telling it to turn on at a higher temp than 160. Just like it is supposed to.
If you want to have it run strong, get a chip. Not the OEM 25 year old chip.
Old 04-18-2012, 05:25 PM
Default Re: Cool???
the fan is not the one that came on car factory im sure...it has a adjustable temp/fan on /off on it....160-230....there are 4 sockets as here
+....hot {used}
G....grnd{used}
m....dont know{not used}
C.....{USED} DONT know what this lead is but one of the three black wires off my fan harness is in this spot...does anyone know what this wire does as i did not hook this wire back up to the aftermarket fan i installed.??
the above is for the fan i removed not the one i installed......so i only used the + and - on the new fan
smallblock413
Old 04-18-2012, 06:42 PM
Default Re: Cool???
thats ok i found out that the "C" is for the ac control of the fan...
smallblock413
Old 04-19-2012, 05:14 AM
Might be a good place to wire a 'force fan on' relay and switch to insure the car runs cooler.
