84-87 GN and T-type parts
8.5 non posi 47k original miles 3.42, complete drum to drum $500
Driveshaft for 8.5 rearend $50 Transmission cross member $40 86-87 GN wheels good for cores all 4 for $120 -------- INTERIOR -------- 86-87 GN seats $400 86-87 GN lower door panels $60 chrome/grey upper door trim(strips) $25 per strip Grey rear sail panels(panels around the quarter windows) for t-top car in great condition $40 for both Grey Third brake light $20 85-87 GN seat belt set(10 pieces) $70 I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top . Nice grey arm rests $15 for both Nice blue passenger visor with lighted mirror $25 Gauge surround $35 radio surround $25 Stock GN radio $50 Blue dash pad $120 Grey dash pad $110 T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100 ------------- ENGINE PARTS: ------------- 86-87 Turbo $150 86-87 Turbo can be used as a core $75 84-87 Turbo elbow $25 86-87 MAF $80 GN Front bumper $130 GN rear bumper $100 Alum. rear bumper reinforcement $80 85-85 ECM $40 86-87 ECM $70 Engine frame mounts $35 86-87 dipstickand tube$40 86-87 Factory Oilfiller tube and cap $30 86-87 Scoop for airbreather $20 109 Block $300 crank $325 .020/.020 Turbo crank fresh from the machine shop $150 stock 8445 heads needing rebuild $40 a set 84-85 GN intake $40 84-85 fuel rail $25 Any year injector harness $30 84-85 valve covers $35 86-87 valve covers $35 cam position sensor just the lower part(no cap) $25 84-85 MAF $45 84-85 AC compressor $40 84-85 Alt $35 84-85 turbo adaptor $25 84-85 crossover pipe $35 84-85 Alt $30 8445 heads $40 a set 84-85 engine wire harness $145 86-87 engine wire harness $175 Any other harness on the car e mail I have them all 86-87 Power steering pump $60 86-87 AC compressor $70 86-87 Belt tensioner $70 86-87 Alt. $60 86-87 Main accessory Bracket $80 84-85 Main accessory Bracket $50 Small plastic guide that holds the posi bat cable to the lower front cover $20 84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1500 Oil cooler adaptor with nut $35 Timing cover $30 Turbo rods(2 dot) $40 a set of 6 Turbo flex plate $25 Turbo oil pans $35 each 84-85 control module $50 84-85 coil pack $40 87 GN steering box $40 Fuel pump hanger/sender $50 Turbo gas tank $40 GN sway bars $30 each windshield wiper assembly $15 Complete heater box $100 ------------ Body & Misc. ------------ BQ coded GN transmission 48k $300 BRF tranny $500 Stock 200 4r tranny pan $35 Drivers missor $20 Passenger remote mirror $40 Blackout door handles $25 for both GN Spoiler(GM not after market) all 5 pieces $175 Non Key locking t-top $90+shipping for the set 86-87 Locking t-tops T-top bags $35 GN tail lights with blackout trim $100 Quarter glass with blackout trim $80 3 piece windshield blackout trim $30 3 piece rear window blackout trim$20 Black wheel well trim $50 each Turbo plastic wheel wells $80 each Any other blackout piece e mail me GN hood $95-$150 AC lines $45
MODERATOR on Turbobuick.com |
Re: 84-87 GN and T-type parts
Have metal T top plates that the t-top lay on top of , in great condition $50 for both
Looking for a stock or digital cluster. Do you have one?
I have a stock analog cluster. Id take $50+shipping
Where Are You Located? Iterested In A Few Parts
let know, if u will take 50.00 shipped |
85T/TYPE/HYPE
Im In Mass.
donz
Where are you located, whats your zip, It really depends on the cost of shipping.
mi 48313.....................
Yes I will take $50 for it with shipping included to that zip.
