White 86 T Type
I have a 86 Regal T-Type Limited for sale...I bought it last November from the original owner. I rarely drive it, it hasnt seen rain or snow... This car is rust free underneath the hood and body...Everything on this car is basically brand new. It has fiberglass front and rear bumpers. It has air-bag suspension in the rear with the fittings installed in the rear bumper for easy fill and deflate...The body has 101,090 miles on it....Motor was fully refreshed at about 80,xxx miles.It has leather seats which are basically new with a few wrinkles...6 point roll cage...im sure im forgetting alot but, I have a folder full of maintence and mods that dates back to the original owner.asking $13,500 obo...if you have anything to trade i might be up for it depending on what it is.
Mods include: RJc racing intake plenum with 60mm throttle body/spacer 6 point roll cage Bigger Fuel pump Bigger injectors Comp cam Fuel pressure regulator 3 inch electic Cutout 2.5 stainless stee turbo back dual exhaust New OEM exhaust Manifolds New OEM stock turbo ported with bigger exhaust housing New msd plugs and wires Brand new Hoosier street slicks...with only 100 miles on them Front and rear sway bars Hotchkis control arms Line lock rebuilt trans with 3200 stall and Art car converter B&m deep trans pan Polyurethane motor mounts trans mounts Here are some pics, i can take more if your interested... Last edited by Keller; 09-25-2008 at 06:15 PM. Reason: Removed duplicate text |
Re: White 86 T Type
nice clear car..
Re: White 86 T Type
Sure its an '86? The grille is '87, and I thought there were no '86 Limited T's made...
Re: White 86 T Type
It has a grand national grill and a fiber glass front end...
Re: White 86 T Type
Really didn't answer my question. Can you provide the VIN? You can leave off the last 6 digits, since those are the production sequence number. Just want to compare to production codes.
Re: White 86 T Type
he must have put the limited seats/console in there b/c as Scott stated they didnt make T-Limiteds in '86 AND if you look at the upper door panels, they are from a T and not a LTD..... so its a "hybrid"
Re: White 86 T Type
Good eye.
The dash and door panel trim looks dark enough to be '87. Can't see if the steering wheel center says "T" or "T Type". Also cant' see the cruise actuator under the hood to note its size or the knock filter for the BLO or HKP on it.
Re: White 86 T Type
Vin: 1g4gk4770gp426853
Re: White 86 T Type
The 4th digit is a G - Regal, but not a Limited (which would be an M). Does have the leather seats, however. Perhaps an option or added later? RPO codes in the trunk could tell.
The 10th digit is a G, so that is definitely an '86, as stated. H would be '87. Regardless, a nice clean car. Like the white ones.
