Replacement Radiator
Need a little help on deciding if I should replace the corroded radiator with a standard replacement brass/copper one for the '87 turbo buick or go with an aluminum one? If an aluminum one, should I go the all aluminum, and if so what is a good place to get one for? Or should I go with the F-Body aluminum/plastic tank (not sure what year if I go this route - will it fit directly) radiator.
Thanks |
Re: Replacement Radiator
Thanks Phil, I looked at that, one from Summit, not sure about the correct year for a Camaro one from a parts store, or if I should get a replacement '87 one from the parts store. I was trying to find more info and input on whether a cross-flow or downward flow is better, dense fin spacing vs not so dense, at the same time aluminum vs the copper/brass. Copper/brass dissipates heat better than aluminum, but aluminum is lighter. I guess I am trying to get a feel for what the rest of the turbo buick people have, such as yourself, to help convince me what to get for a replacement radiator.
im using the f-body radiator, with dual fans
What year of camaro, any problems with plastic tanks, and how does it compare for physical dimensions versus the original radiator?
Thanks |
you have to add, coolers if you want to run the factory oil cooler and a trans cooler will have to be added.
http://www.gnttype.org/techarea/airc.../fbodyrad.html |
Phil, thanks for the link, I was looking for something like that. How different are the two radiators in size, the F-Body vs the original that is? Also, can you tell a different in temperature? Would you still recommend the g-body radiator or do you think that is over kill vs getting plenty of cooling with F-Body radiator.
the f-body is almost a direct bolt in, other then the addition of the external coolers you have to add.. I perfer not to use an engine oil cooler, and most people that have blown there engines dont reuse them anyhow.. But a new stock style radiator or the f-body.. they will both work great. it just comes down to your preference.. My daily driver GN has a factory replacement with all the coolers, works great..
The F-Body is definitely cheaper at $120 vs the $450 for G-Body, but the G-Body is a 3 core all aluminum vs the 1 core plastic tank F-Body. I think the G-body also has the built in tranny and oil cooler.
http://cgi.ebay.com/ebaymotors/Grand...spagenameZWDVW http://cgi.ebay.com/ebaymotors/BUICK...spagenameZWDVW |
