Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Turbo TRader > Cars FOR SALE
Old 08-23-2004, 05:30 PM
Grand Nash Grand Nash is offline
Grand Nash is on a distinguished road
Default Price lowered...... Mint 86 T-type For Sale (pa)
1986 REGAL T-TYPE (Restored HARD TOP) - FOR SALE. $15,500 Firm. OVER $18,000 INVESTED.
COLOR – LIGHT CHESTNUT MET. (EXTREMELY RARE)
2 OWNERS………………79,100 MILES. PA INSPECTED THRU 9/04.
ONLY 200 MILES ON THE CAR SINCE RESTORATION WAS COMPLETED.
**NEW EVERYTHING: ENGINE, PAINT, INTERIOR, WEATHERSTIPPING, ETC…**
I HAVE RECIEPTS, BEFORE & AFTER PICTURES TO VARIFY ALL WORK THAT WAS DONE. ALL RECIEPTS GO WITH THE CAR IN A FULL 2" THICK BINDER.
SOME OF THE CARS OPTIONS:
ELECTRONIC CLIMATE CONTROL (RARE, IN PERFECT WORKING ORDER. AC BLOWS ICE COLD WITH ORIGINAL R-12 FREON.
POWER ANTENNA
POWER 6 WAY 55/45 SPLIT BENCH SEAT (RARE)
MAP READING LAMPS
NO CRUISE WHEN ORDERED (I ADDED THE “FACTORY” CRUISE CONTROL)
TILT COLUMN
REMOTE MIRRORS
POSI REAR
BLACKOUT TRIM
POWER WINDOWS / POWER LOCKS
THE CAR IS LOCATED IN PA JUST 20-25 MINUTES SOUTH OFF I-95 FROM THE PHILADEPHIA INTERNATIONAL AIRPORT OR 10-15 MINUTES OFF I-95 FROM THE PA/DEL BOARDER.
SERIOUS INQUIRY'S ONLY PLEASE.
E-mail: BUICKTURBOPERFORMANCE@YAHOO.COM
Phone: (610) 306-1623 Anytime
If I do not answer please leave a message and I will return your call asap.
CLICK HERE FOR PICS AND MORE INFO ON THE CAR.
ENGINE:
NEW GM “109” SG1 FACTORY REPLACEMENT SHORT BLOCK
STOCK RECONDIONED HEADS
NEW John Craig TA-49 (Only 10 miles on it.)
NEW ADJUSTABLE WASTEGATE ACCTUATOR
FENDER DUMP WITH ELECTRIC CUTOUT
NEW AC-DELCO WASTEGATE VACUME HARNESS
NEW HEAVY DUTY INTERCOOLER COUPLNKS & STAINLESS CLAMPS
REFINISHED HEADERS / DOWNPIPE
NEW AC-DELCO DOWNPIPE EXHAUST GASKET
NEW 009 42.5lb INJECTORS
NEW ACCUFAB ADJUSTABLE FUEL PRESSURE REGULATOR
NEW BILLET VACUME POD W/TAP FOR VACUME BRAKE CONVERSION
NEW WALBORO 340 INTANK FUEL PUMP
NEW CUSTOM FUEL PUMP HOTWIRE KIT
NEW HIGH PERFORMANCE SPARK PLUG WIRES (KIRBANS)
NEW AC-DELCO CTS-43 SPARK PLUGS
NEW AC-DELCO COOLANT HOSES (ALL)
NEW AC-DELCO INTAKE VALVE SEALS
NEW AC-DELCO MINI HIGH TORQUE STARTER
NEW AC-DELCO BATTERY
NEW AC-DELCO INTAKE GASKET
NEW AC-DELCO COILPACK & IGNITION MODULE
NEW HIGH FLOW RADIATOR CORE W/RECONDITIONED STOCK END TANKS
NEW FELPRO (RUBBER) VALVECOVER GASKETS
NEW FELPRO FRONTCOVER GASKETS (NEOPREME)
NEW HIGH VOLUME OIL PUMP
NEW TIMING CHAIN / GEARS
NEW AC-DELCO TIMING CHAIN TENSIONER & SPRING
NEW AC-DELCO WATERPUMP
NEW CAM BUTTON (ATR NEEDLE BEARING)
NEW AC-DELCO CAM SENSOR
NEW AC-DELCO EGR SILONIDE
NEW AC-DELCO EGR VALVE
NEW AC-DELCO PLENUM, THROTTLEBODY GASKETS
NEW BILLET ALLUMINUM THERMOSTAT HOUSING & 160 DEGREE STAT.
NEW AC-DELCO OIL COOLER LINES
NEW RJC POWER PLATE
NEW K&N AIR FILTER
NEW FUEL FILTER (AC-DELCO)
NEW ORIGINAL GM, AC-DELCO HOOD LINER
NEW WASHER & COOLANT BOTTLES
FIRE WALL WEATHERSTRIPPING
CHROME MASS AIR PIPE
CHROME UP-PIPE
NEW AC-DELCO MOTOR MOUNTS
NEW ENGINE TOURQE STRAP
MINT INTERCOOLER AND SCOOP OUT OF A 5,000 MILE CAR
NEW SENSORS:
TPS, IAC, OXY, MAF, MAT, KNOCK, CRANK, AND OTHER MISC. SENSORS
BIGGY OIL FILTER CONVERSION (AC DELCO PF-24 FILTER)
TRANSMISSION:
BRF - 200 R4
HEAVY DUTY 2600 STALL TORQUE CONVERTER
NEW TCC SILONIDE
700R4 FILTER & NEW DEEP ART CARR ALLUMINUM TRANS. PAN.
NEW TRANS COOLER (B&M SUPERCOOLER)
NEW AC-DELCO TRANS MOUNT
REAR:
ORIGINAL 8.5” GM LIMITED SLIP, POSI REAR W/3.42 GEARS
NEW (KIRBANS) REAR VARIABLE WEIGHT SPRINGS
NEW REAR MONROE SHOCKS
FRESH REAR GEAR OIL CHANGE
FRONT SUSPENSION:
NEW MOOG UPPER AND LOWER CONTROL ARM BUSHINGS
NEW MOOG BALL JOINTS UPPER & LOWER
NEW MOOG IDLER ARMS
NEW MOOG CENTERLINK
NEW MOOG INER & OUTER TIE ROD ENDS
NEW MOOG TIE ROD ADJUSTING SLEVES
NEW MONROE SHOCKS.
NEW MONROE SPRINGS
NEW MOOG SWAYBAR END LINKS
NEW POLY SWAYBAR FRAME BUSHINGS
NEW INNER & OUTER WHEEL BEARINGS & SEALS
CHASSIS/FRAME:
NEW ENERGY SUSPENSION POLYURETANE UPPER & LOWER BODY BUSHINGS (GNX BUSHINGS ADDED)
NEW FRAME BRACES - CROSSMEMBER TO FRAME, FRONT FRAME CROSS BRACE, CORE SUPPORT TO FENDER BRACES, REAR SEAT BRACES.
REFINISHED GAS TANK
FRAME / UPPER & LOWER A-ARMS / REAR END HOUSING / FLOOR PAN (INSIDE AND OUT) - ALL SANDED AND COATED WITH 2 COATS OF EASTWOODS (MAT BLACK) RUST ENCAPSELATOR.
BREAKS:
VACUME BREAK CONVERSION W/NEW MASTER CYLINDER & BRAKE BOOSTER.
REAR BREAK DRUMS TURNED W/NEW BREAK SHOES INSTALLED
DRUMS WERE BEAD BLASTED & REFINISHED
NEW REAR WHEEL BRAKE CYLINDERS
WHEELS:
REFINSHED SET OF (4) FACTORY T-TYPE WHEELS. PROFESSIONALLY REFINISHED BY TRANS WHEEL WITH POLISHED SPOKES AND RUNNERS. (SHOW QUALITY)
EXHAUST:
NEW 2 ½” HOOKER DUAL CAT. BACK ALLUMINIZED EXHAUST WITH AREO CHAMBER MUFFLERS. & ALLUMINIZED TEST PIPE
INTERIOR:
NEW HEADLINER, & CARPET.
SUN VISORS RECOVERED
CONCERT SOUND ADDED
FRONT SEAT REAPOLSTERED
LOTECK 3 GUAGE POD
NEW AUTOMETER SPORT COMP. ELECTRICAL OIL PRESSURE, COOLANT TEMP GUAGES. MECANICAL 30lb VACUME/BOOST GUAGE
STEADFAST STEERING COLUM GUARD
ALL TRIM, BACK SEAT PROFESIONALLY CLEANED / REFINISHED
ENGRAVED POWER 6 DOOR PANEL SCREW COVERS
ALL NEW GM WEATHERSTRIPPING UPPER & LOWER DOORS.
EXTERIOR:
NEW FIBERGLASS BUMPER FILLERS
NEW FIBERGLASS STICK ON FACTORY LOOK ALIKE SPOILER ADDED
FRONT & REAR CHROME BUMPERS - BUFFED/POLISHED
ALL NEW GM EMBLEMS
FACTORY METAL DOOR EGDE GUARDS ADDED
REFINISHED 86 T-TYPE GRILL & EMBLEM
NEW HEADLIGHT BEZZELS
NEW FRONT & REAR BUMPER RUB STRIPS
NEW HEADLIGHTS / HIGH BEAMS
NEW PARKING LAMP BULBS / TURN SIGNALS / BRAKE LIGHTS / REVERSE LIGHTS
TRUNK:
IMM AUTO SPECIALTIES TRUNK KIT (BLACK) WITH “T-TYPE INTERCOOLED” EMBROIDERED ABOVE THE SPARE TIRE COVER
NEW TRUNK WEATHERSTRIP SEAL.
THANKS FOR LOOKING.............................Ed
Old 08-26-2004, 01:27 PM
Default Re: Mint 86 T-type For Sale (pa)
To The Top
Old 08-30-2004, 08:46 AM
To The Top
Old 09-07-2004, 07:41 AM
TTT Negotiable
Old 09-13-2004, 07:51 AM
Ttt..........
Old 09-16-2004, 11:02 AM
To The top...........Negotiable, Great car
Old 09-20-2004, 08:34 AM
To The Top
Old 09-27-2004, 11:18 AM
To The Top
Old 10-06-2004, 10:08 AM
Price lowered $15,500
TTT
Old 10-11-2004, 08:51 AM
To The Top
