Go Back   GN and T-Type Performance Enthusiasts (GNTTYPE) Forums > Add-on Electronics and Electrical > General Electrical
Old 10-06-2009, 10:25 PM
diamondavet diamondavet is offline
diamondavet is on a distinguished road
Default fuel pump blowing fuses
hi i have a 87 gn and i just put a new fuel pump in it and it worked for 2 weeks and now it blows 30 amp fuses like nothing where do i start thanks grandnationaldave@yahoo.com
Old 10-07-2009, 12:10 AM
Question Re: fuel pump blowing fuses
- What pump did you install?
- Why did you change the pump?
- Are you sure that no wires are shorting out, etc.?
- Do you have a hot wire kit? If so, did you install it at the same time?
- Do you hear the relay clicking at key-on? (when the fuse is not blown...)
