| This is a general site search and does not include list archives. | |||||||
87 gn, t-top 3k on motor, bigger injectors,38's, te-34, body straight, not much rust at all, interior rough, but good solid 4500$ car. Call for info, 941-626-4715 Matt
where are you located?
sarasota fl
Can I have some pics please? Particularly of the areas with rust. nowhatisthat@msn.com
pics here too. does it have ac and heat? any issues? the motor forged or stock rebuild thanks
Please send pics to:
dansch@naptools.com |
please send pics to futiaz28@aol.com
thanks |
T-TOP CAR WITH 92.5K ORIG MILES
CLEAN TITLE 3K ON MOTOR REBUILD Car is a PROJECT, meaning needs paint, new front seats, but runs and drives Rebuilt motor Moly rings Comp 206 cam Comp valve springs Fresh 3-angle valve job Port and bowl work done to the heads Comp double roller timing chain Melling high volume oil pump Melling cam button TE-34 Turbo (T3/T4 57 trim 545hp capable) Specs on TE-34 at Precision Turbo 38 lb injectors ATR 3 inch SS downpipe, with external wastegate and test pipe Hooker 2.5 inch dual exhaust Custom 3 inch intake pipe with K+N filter Adjustable Fuel Pressure Regulator Walboro 340 pump and rewire kit Scanmaster 2.1 Alkycontrol.com burned ecu chip 225/60/15 front tires 275/50/15 rear tires All tires are like new BFG Radial T/A New filler panels Fresh header panel (current one is cracked) Extra dash panel in excellent shape (to replace cracked current one) Extra steering wheel in excellent shape (current one has minor cracks on top) Digital dash (option compared to the sweeping needle) Shift kit in the tranny Power windows Power locks 4th gen camaro rear view mirror (has built in map lights) 3rd gen camaro tag bracket (folds down and stays down, compared to stock which is spring loaded) Call Matt at 941-626-4715 |
| Bookmarks |
